Are pcc105 (4 pack) filter cartridges the same as a cpp420 (4 pack) filter cartridges
Nunyabizniz
12
Nevada, Las Vegas
In my Pentair Clean & Clear Plus there are 4 pcc105 peatco filters. Looking those up I found these replacement part numbers:
817-0131, 178584, R173476, 817-0106​
Which match the same as part numbers as ccp420 filter cartridges. Reason I ask is because there is a difference in pricing, with the ccp420 being cheaper in cost.
No model number on the pentair.
All the filter cartridges you gave number for are 7" across, 26" long with 3 inch holes top and bottom.
You gave no part number for the "ccp420" filter cartridges. So don't know what we are comparing to.
You can tell which one you have based on dimensions...
Reactions: Nunyabizniz
From Leslies website, In the swim Pentair Clean and Clear plus 420 ccp420
Dimensions: Length: 26 inches; Outside Diameter: 7 inches.
  • Opening Sizes: Top Opening: 3 inches; Bottom Opening: 3 inches.
  • Filtration Area: 105 square feet per cartridge.
  • It Also says Pleatco #: PCC105
From
Cartridge Set (4PK) Replacement For Pentair® Clean & Clear® Plus 420 by Optimum Pool Technologies​
Replaces: Pentair® CCP420 Cartridge (Filter PN 160301)
Replaces parts: R173476, Pleatco®# PCC-105 / PCC105, PCC105-PAK4,
  • Number of Cartridges: 4
  • Inside Diameter: 3"
  • Outside Diameter: 7”
  • Length: 26-1/16”
I suppose I found my answer saying the one from Optimum Pool Technologies are compatible with Pleatco pcc105
I was just confused why they sell them differently and have one higher priced than the other, If that is truly the case.
