Aquarite S3 Omni.
ChrisABS
In The Industry
Jul 11, 2023
365
Ohio
I am about to install and Aquarite. It’s the S3 series that also has some Omni functionality with the 4 pin controller like an Omni PL or Logic. I am wondering what the amp draw would be so I could purchase the right one. Also does it need to be GCFI breaker? Thanks!
115V - 2 amps or 240V - 1 amps.
It should not be put on a GFCI CB.
VOLTS X AMPS = WATTS
If you increase one, the other decreases and watts stays the same.
You cannot talk about one without knowing the other to keep watts constant .
