Hi, I keep reading that the vs pumps need continuous power and that the vs pump needs to be hard wired. But in the aqualink manual, it shows that the pump needs to be connected to the relay such that the 240v line wires go in slots 1 and 3 and the load wires go in slots 2 and 4 of the relay. So if i do that, the pump is NOT getting continuous power....it's only getting power then the relay is switched on.
I'm trying to solve a problem others have had. In my web based system setup, i click vs pump and it shows 4 "epumps"....my specific pump is not listed. Also, in the list of RS485 devices, it shows (i) Aquapure 1 (ii) iAqualink wifi 4 and (iii) gas heater....but doesn't show my pump. I've triple checked my wires to make sure they're all screwed down tight. My only thought is to ditch what the manual instructs me to do and HARDWIRE the pump to the relay.....meaning both load and line go into slots 1 and 3 of the relay. Any help will be greatly appreciated.
