Aquacal sq225 heat pump wiring question
I see the red and black line voltage wires go below the label saying line voltage here but where does the white wire go? I was planning on using 4 wires including a ground. Thank you very much!
A 240 volt device does not always use the white neutral wire.
What model heat pump are we discussing?
Show us a picture of the label and power connection.
It's the same one as above. It's an Aquacal SQ225 single phase.
That should just connect to black and red hot 240V. No white neutral. Plus green ground and #8 copper bonding wire.
