Moved from here.
Wondering if you are still on this site. I have the same problem as the guy in this thread had. Today when my pump came on i ended up with a oil or lubricant film on the top of the pool water. It looks like fuel because of the rainbow effect like fuel has when in water. But it's not fuel . The same thing happened a couple of months ago and i had the fire department come out and check. No one has been in the pool. No work has been done around or to the pool . Last time i ended up getting Pigpads to get the oil out. What could cause that to get into my pool? Could it somehow be from the pump?
Ahhh - a pool store potion.
Be aware many of those plug up your filter. We do not recommend using any pool store potions. Chlorine will do the same thing.
