Re: Flocculant
Thanks for welcoming me ,Chem Geek,
By adding DE to a sand filter you may get some filter blocking.
Don't forget that a typical DE Filter has a filtration speed of about 2gpm/ft2 compared to the speed of a sand filer which could be anywhere between 15-20 gpm/ft2.
Also DE is organic based , therefore it will react with the chlorine
by creating more combined chlorine. For this reason Perlite should be used instead of DE.
You are correct in saying that with elevated chlorine levels you could achieve clear water, however - the higher your chlorine levels are , the more
DBP you'll create.
With a proper flocculation process we are trying to capture those small organic impurities (bacteria, viruses), which are mostly introduced to the pool by the bather. By taking out those beforehand we have to disinfect / oxidise less afterwards ,allowing us to run at lower chlorine levels.
The NSPF recommends a FC residual of 2 - 4 ppm in public swimming pools. IMHO this is way too high, since with those high doses of FC ,we also create high doses of DBP. I guess the reason behind NSPF's guidelines is that the microbiological aspect is being met, which I am certain it does. With 2-4 ppm it's no surprise. . :lol: .
It seems in North America we forget about the byproducts of chlorination. In Germany very strict guidelines apply - max. THM's in the pool water is
20 ppb (microgram/liter) . I wonder how many public swimming pools in North America had their water tested on THM (80% or so being Chloroform) and TOC.
The NSPF Pool Operator Handbook ( CPO) mentiones very little about it ( page 46) , except it says that "Currently the risk to human health due to THM is relatively low". .
Hard to believe no guidelines are being set, since there is so much research out there clearly demonstrating that THM's are linked to cancer. Link ->
http://www.ncbi.nlm.nih.gov/pmc/article ... 8-0088.pdf
This article was published in 1994 - at the end it says that UV radiation should be considered. Meanwhile research has shown that UV radiation should not be used in chlorinated pools, since it raises THM levels up to 300 %. . .Something we did not know back in 1994. This is something which should be mentioned in the NSPF Pool Operator Handbook as well.
Links on UV radiation in swimming pools ->(written in french with some english) ->
http://www.inrs.fr/inrs-pub/inrs01.nsf/ ... nd2237.pdf
And another one ( french and english just below ) ->
http://www.water-quality-journal.org/in ... er/2009009
The German approach is to run with as little as possible FC by still maintaining microbiological safe and healthy water.
You will find this article very interesting - it clearly demonstrates that it is achievable to run a public pool between 0.3 - 0.6 ppm by still maintaining proper sanitation ->
http://www.lims.hu/media/furdokonf/Engl ... ger3_p.pdf
