As Pat says, there are orings in the valve. You need to pull the valve apart -- you gently pull the two tabs outward and the valve comes apart. Check the orings and see if they are damaged. Lube them and put it back together.
Hummmm. By any chance was the relief valve left out all winter?
What I described is getting to the orings in the valve itself. Your leak out the nozzle is what happens when they need replacement or lubrication. I lube them in my valve every year when I clean the cartridges.Thank you both! I should have specified that the water is coming out of the nozzle where air and water release from if you turn that assembly to release the air, it’s not leaking around the base of the valve. Is that still likely a gasket/o-ring issue?
Well, unless someone else can confirm, I have a suspicion the freezing temps may have damaged the valve. Maybe. I'd like another member who uses those all the time to confirm. Let's see.It was, yes. They left it there when our pool was closed for the winter.
There you go! Marty pulled-through.What I described is getting to the orings in the valve itself. Your leak out the nozzle is what happens when they need replacement or lubrication. I lube them in my valve every year when I clean the cartridges.
There you go! Marty pulled-through.I hope that does the trick for you. Hint - many folks do remove fragile components (i.e. gauges) at closing ...... just in case.
I hope the internal o-ring solves your issue.
Non-Teflon? I just checked Amazon for Magic Lube and they all appear to be Teflon based.Look at the valve. You turn it to release the pressure. See the two tabs on the outside? Lift those outward gently and the valve will turn and come apart. You do not remove the entire assembly from the housing. Obviously, your pump is off and the Circuit breaker is opened (off) to the pump.
Use a non teflon silicone lubricant. Magic Lube is one brand. You need to have some to lube your pump basket gasket and your cartridge filter gasket.
Our pump runs 24/7 (as per our pool tech’s instructions) so that should be ok? You have been incredibly helpful. Thank you berg much for everything! I will check with our local pool store when the open tomorrow morning to see if we can pick some up. Have a great evening!The drip is fine. It may let the system drain when the pump is off so you may see alot of air when the pump starts.
Magic Lube 2 or Boss 820 are the ones I know of. I use Boss 820.
Honestly, I’m not sure either - seems like a huge waste of electricity in my opinion. I would even be fine with running it during the day and turning it off at night while it’s covered. Maybe I should get a second (or third, rather) opinion on that. Thanks again!Can't imagine why you need to run your pool pump that much but that is your decision. As you do not have a SWCG all you need to run it for is to mix your daily addition of liquid chlorine. With a pool cover you do not even need to skim.
Good luck.
