- Jul 13, 2011
- 65
- Plaster
- Hayward Turbo Cell (T-CELL-5)
I just recently noticed air bubbles entering the pool through the pool jets. There’s also a significant amount of bubbles in the pump basket, and when the pump stops, the system loses its pine. I’ve had this happen in the past and the culprit was a leaky gasket on one of the valves leading to the pump, and I discovered this because when the pump is off water would leak from the valve gaskets. Now, when I turn off the pump, I did not see the presence of water anywhere in the pool pump area, however, the system does lose its prime. My assumption is that air coming into the system is due to a leak prior to the pump, dry air Into the water. There are two sources of water, once in the main drain and one in the filter basket. I can shut each one off individually, and the air remains in the system, which leads me to believe the leak must be after the valves. Is my logic solid? What else might I look for
Thanks in advance
14K SWG In-ground
Thanks in advance
14K SWG In-ground
