Hello TFP,
I'm completely out of ideas on how to remedy air coming from one of the 6 return lines in my spa. This is the only return line with bubbles, and it is a small amount of fine bubbles that come out. If I turn the fitting off for that specific jet in the spa, the bubbles will relocate to another return until I re-open that fitting, and then they move back.
I know from reading through other forum entries that the general consensus is that this is a suction side leak, but I have now almost run out of potential plumbing areas to look at. Here is what I have tried:
Does anyone have further suggestions? Or should I just live with the bubbles?
EDIT: In case this is relevant, I see no bubbles in the pump basket...
--tethys
- Removed my (unused) in-line Rainbow chlorinator, and capped off the plumbing (good riddance!)
- Replaced all 4 check valves, ensured that gaskets had some magic lube applied
- Replaced the air relief valve on top of my Hayward filter, and lubed the gaskets (it would drip every so often, so needed to be fixed anyways)
- Replaced the pump lid and gasket
- Spotted and fixed a hairline crack in one skimmer wall with epoxy (2 skimmers total, the other one checks out okay)
- Soaped up all of the other fittings on my equipment pad - including all actuator valves and drain plugs in the pump, heater, and filter - no signs of a leak anywhere
--tethys
