Advice on replacement equipment setup
SplashDamage
15
Northern CA
I'm in the middle of getting quotes to renovate our 30 year old pool, replaster, new tile, coping... the works. But as our equipment is all 15+ years old that have given us headaches over the recent years, we figure it's time to bite the bullet and replace it all. We just want a reliable, smoothly running beautiful pool. I've been spec-ing out what I think should be what I need.
I'm located in Northern California, in-ground pool is ~20,000 gallons with a raised spa w/ spillway. Currently have a DE filter, but looking to move to cartridge to avoid the messiness of cleaning and recharging it.
Here's what I've put together:
PartItemItem #
PumpPentair IntelliFlo3 VSF 1.5HP w/ relay11066
FilterPentair Clean & Clear Plus, 320 Sq. Ft. Cartridge FilterEC-160340
BoosterPentair HydroBoost Booster Pump 360526360526
ControlsPentair IntelliCenter i10PSIC40 Kit - Pool and Spa with Load Center and IC40521908
Pool LightPentair IntelliBrite 5g Color LED Pool Light 120v, 30'601000
Spa LightPentair IntelliBrite 5g Color LED Spa Light 120v, 30'640120
HeaterPentair MasterTemp 300K BTU Natural Heater460734
I'm not very pool savvy, I just basically manage the chem levels and regular cleaning/maintenance. I don't know much more beyond that, so any feedback on if this seems like an appropriate setup and/or other things to consider before we undertake the project would be greatly appreciated!
A booster pump just uses more energy and you also have to run the VS pump at a higher speed when running the pressure side cleaner.
Have you considered either a corded or cordless robot cleaner?.
Just convert that pressure cleaner line to another return and make your plumbing simpler.
Also add a heater bypass
Reactions: Lake Placid
No you don’t.
As long as the filter pump is running the booster pump does its work.
Thank you, I'll definitely look to get the heater bypass added - that seems like a wise decision!
