Wanted to check with some of you that have motor bearing replacement skills.
I have a bearing going out (shaft end) on a Jandy JEP1.5 pool pump. It is 4 years old. In addition to repairing the motor, I plan on installing new internal pump parts and seals. I pulled it apart and lubed the bearing but it still making some noise.
The motor is an AO Smith Variable speed 48Y square flange, single phase. I have inquired elsewhere and they recommend replacing the whole pump/motor or taking the motor to a rebuild shop. ... What?
My local shop wants $170 to replace bearings. Thats not oo bad but ... bearings are only $10-$15, right? The bearing is a 6203-2RS (Maybe an SKF?)
Has anyone tackled a variable speed motor bearing replacement? Why would it be any harder than a single or dual speed motor?
I do have mechanical skills (gear pullers, press, etc) and have rebuilt gearboxes and other devices with new bearings.
Advice please.
Advice please.
