- Sep 6, 2011
- 4
I’m looking remodel my pool area and take an existing waterfall, increase its size and have it fall into the pool. The existing waterfall used to have it’s output come from the pool equipment pad and then the basin drained into the pool. The output was capped over and buried under concrete due to what I believe must have been a leak. I plan to keep the existing waterfall inside of my new waterfall grotto with about 95% of the flow going to the new waterfall dropping about 8 ft into the pool. The other 5% will feed the “inside the cave” waterfall that will overflow into the pool. Ok enough preamble, now on to the part I’m trying to work out in my head and can use some advise.
I wish to inline plumb a 9000gph high flow pump to feed the waterfall. My choices as I see them are to:
1. Replace or modify the pool skimmer so that it feeds the waterfall pump as well as the main pool pump. I would remove a section of concrete pool deck around the skimmer and add the line and re-pour.
2. Remove a section of concrete pool deck and dig down to add an intake line to the waterfall and intake screen in the pool.
Currently the liner is removed.
I plan on using 3” intake/output plumbing for the waterfall.
A. In scenario 1 Can a pool skimmer handle the flow of a 9000gph 3” pump AND the 1.5hp 1.5” pool pump? The only reason to do it this way would be to have one less intake in the pool.
B. In scenario 2, should I use a 3” bulkhead fitting for the intake line as it goes through the pool wall or is there another way?
C. Is there another scenario or way to get enough pool water to the waterfall pump?
Some pictures of the current setup and distance from skimmer to waterfall and a picture of a similar goal waterfall.
