- Mar 1, 2017
- 56
- Plaster
- Pentair Intellichlor IC-40
My son has a one year old 20K gallon pool with a Jandy Aqualink control center and a Nature-2, Fusion TriChlor tab chlorinator. Unfortunately, his weekly pool service company has been dropping trichlor tabs like candy into the feeder for one year now without considering climbing CYA levels, now measuring over 220ppm after only 12 months. The service guy is keeping chlorine levels over 8ppm to (in his words) "keep algae at bay."
When I built my pool 12 years ago, I had exactly the same issue with my pool service company. My CYA level was over 300ppm and the service company was keeping my chlorine levels near 10ppm - so I fired them, drained and refilled the pool - switched to a salt system in year #2 - and now service the pool myself and have never looked back. - all is good.
I'm recommending my son do the same thing (switch to salt) unless someone can convince me it's worth keeping the Nature-2 tab feeder. From what Nature-2 claims, you should be able to keep chlorine levels at .5 ppm with the mineralizer active once the pool is drained and CYA is brought back down to normal levels. So here are my questions:
Cheers and thanks . .
MB
- Do we keep the Nature2 Fusion tab feeder or switch to salt? IMO, switching to salt and maintaining stabilizer levels myself has been much easier, but perhaps with the right person monitoring the pool, this system can work just fine.
- If NO to above, which salt system would work best?
- Nature2 FusionSoft (I assume drops right into the same spot as the outgoing Nature2 Fusion with no plumbing changes).
- Jandy Aquapure PLC1400
- Other?
- His Aqualink control panel does not have the power supply and LCD board required for a salt generator - so is the Jandy Aquapure with PureLink a better fit, or does the Nature2 FusionSoft use the same power supply?
- For both salt generators above it appears from what I can gather on the net - that one must purchase BOTH the salt cell AND a power supply. The Jandy Aquapure PLC1400 sells for approx $995. I assume one must fork out another $995 (approx) for a power supply?
MB
