The details of my pool setup are in my sig, but basically stock sand filter + salt water system with the dual outlet ports on the pool.
Currently i just use the side floating basket as the skimmer.. while one of the two ports are blocked to allow for better skimming.
I've read on here and various other places of people adding a "hayward" skimmer to the side by cutting a hole..
I'm trying to wrap my head around how it would interconnect and if it would mean that i couldnt use the hose attachment anymore, for vacuuming the pool?
Would it also work with the existing pump and setup, possibly just requiring a converter for differences in tube sizes perhaps?
There was a good thread on this here, but it appears the pictures are all gone/missing.. The videos online i've seen only seem to show the end result (no cutting etc)
I originally assumed i had to do this before filling the water levels back up (I already took the cover off, started filling it back up, then stopped thinking maybe now rather than next year).
edit: sounds like you can technically install this even after the water levels are at the season open level.
It sounded as if you could basically mount it say near the second port, maybe an inch down from the top edge (one block visible) and cut the whole attach it and the hoses and be done.
My pool left to right has the inlet port that blows the water back in from the sand pump first.. then a few feet and you are at the two outlet ports ( I O O ) basically.
**Would it just connect on the Y tube portion that splits between the outlets?
Any thoughts / suggestions and also which exact skimmer do i want to go for here? Any risk that the hole i cut fails and im out a pool or have a major patch to do? (looks like you just screw the bracket in place and make a cut inside it, i think)
EDIT: i think the item needed is just this $36 one here? (SP1091LX)
Thanks in advance
EDIT:
here are some pics:
Thanks in advance
EDIT:
here are some pics:
