I discovered that a switch can be added to mechanical timer that will shutdown heater 20min before pool pump. Sounds like a good idea, and I'd also like to put my SWG in that circuit as well.
Is there any problem in connecting SWG and heater to same switch? The two have combined 3 amp draw, and the switch is rated for 10a, so it seems like it would be ok. I'd just need to connect one lead from switch to load side of timer, and the other switch leg to one leg of heater and swg, correct?
Are there any wi-fi pump switches that have multiple timed outputs?
