I have a 16 x 48 Coleman above ground pool that is a few years old.. Trying to find an adapter to hook up a vacuum too does anybody have any suggestions...
Welcome to TFP! Do you have a thru-wall skimmer, or just the suction port in the side wall? Maybe post a pic or two of your set-up? Have you ever considered the stand-alone water pressure vacuums? I think we have some people that have used those in the past.
When i had one of those pools & manually vac’d I would just use the siphon method & go very quickly. That way it by passed the pump/ filter all together.
Basically put vac head in pool, let vac hose fill up w/ water, put hand over end of hose, then throw end of hose over the side of the pool to the ground.
