Above ground pool wall thickness
cj133
719
NJ
I've got an odd question.
Does anyone know what the typical thickness of the steel wall is?
Specifically I'm looking for what thickness steel a uni-bead liner is intended to go over.
My pool is assembled so I have no easy way to get a measurement.
Shouldn't be enough difference in any steel wall thickness to matter. I'd say 1/8 would be pretty standard. Liner will be held in place the top rail itself or possibly a liner "clip" that runs between the uprights and under the top rail. Think of it as a cheap binder with a plastic sleeve used to slide down the edge.
