Hi guys, looking for some ideas on heating a above ground pool.
Here is my current setup:
10ft framed Intex pool round
Elecro 3kw Nano Above Ground Swimming Pool Heater
Sand filter/pump (Ultra Sand Filter & Pump Combo System for Intex and Bestway Above Ground Swimming Pools)
I have a disabled son who is a pain and won't get in the water unless it's 28°c or over.
With the current set up I can get it to about 25, but anything more is using a hose with hot tap. So don't want to use so much water having to empty and refill.
Is there anything I can add to quickly get those last few degrees, or is it a change of heater required? I've noticed anything bigger needs hardwiring in.
Thanks for your help guys.
