Above ground pool deeper than 54"
platon20
0
113
DFW/Texas
I am looking into getting an above ground pool but I have a slope on the backyard. I have a deck off the back porch that is approx 6 feet off the ground below.
Is it possible to get an above ground pool that goes deeper than 54" so that it can rest against the ground and be flush with the existing deck? All the pools I have seen have max depth of 54"
Another alternative would be to build a "subdeck" that is a few inches lower than the main deck so that the AGP rests directly on the ground.
there are pools that you can have a deep end but the endges are still all the same depth, only the middle goes deeper. I have not seen a wall higher than 54"
You can dig down and sink the pool. There are semi-ingroung models.
