Hello folks,
New here and thinking of installing an above ground pool on a slight slope. I just poured a concrete slab / patio (as you can see in the picture) and would like to place the pool in the adjacent area next to the concrete. Since its a slight slope, I'd need to build it up a little and compact it.
I wanted to bounce the idea off of you all to see if my thinking is sound. I thought I'd go and buy some of those stackable concrete retaining wall blocks around the entire area that needs to be raised/leveled. Then place some 3" minus base rock - use a motorized compactor, then place some 3/4" minus and compact. Finally, place a layer of sand compacted. Debating on using the foam pads or not between the sand and liner.
The deal is, the soil is clay and can be mushy when wet. I was thinking of the compacted 3" rock as a base and then gravel and then finally a generous layer of sand.
Any thoughts about doing this?
I'm I crazy to think 3" rock for base, or just go with some 3/4" and then compacted sand on top? As far as height in the middle, it will only be about 10" tall as far as the retaining wall.
Any suggestions appreciated.
Thanks in advance.
-J
Thanks in advance.
-J
