- Aug 2, 2019
- 50
- Plaster
- Hayward Aqua Rite (T-15)
Looks like the booster pump to my water feature died. At first I thought it was the cap since the motor was making a humming sound and not rotating. I opened the back cover and the cap was clearly bad and shaft spins free. I replaced the run cap with a new one same rating of 55uf and 450V instead of 370V. However, I'm getting nothing now... no buzzing or anything. I checked the voltage and getting 240V and 120V on each leg to ground. Also used the incandescent light bulb test on each leg to ground and the light turns on normal brightness so current flow is good. I'm at a loss for what could be causing the issue now when it seemed like a cap and I know the motor hasn't been on except for a few seconds for testing. Anyone have any insight to how the wires coming out of the motor should ohm out? I saw a procedure from A.O.Smith but it didn't seem to apply since mine didn't have an internal start switch. The 5 colors coming from the motor windings are red, white, blue, black and brown. I might look at the pictures tomorrow to draw a schematic of the initial wiring and see if I can figure out what wires do what for the windings. Any advice from motor experts is appreciated... I don't have the greatest knowledge of induction motors but been learning a lot over the last few days on Youtube.
Also, if I determine the motor is bad I'm thinking about moving my filter pump over to the waterfall/slide then getting a variable speed for the filter. The problem is I'm wondering if the filter pump would flow enough water for the water feature. The current slide/waterfall pump has a noticeably larger housing. Any idea the GPM from each pump? Wondering if it would be adequate.
