I’m brand new to pool ownership. Inherited a pool 4 days ago with zero FC and zero CYA.
~45,000 in ground concrete pool, non SWG.
Pool Math told me to target 3 for FC so I started working toward that with SLAM. It also told me I needed to add 6 gallons of stabilizer. Now, after several shocks and adding the 6 gallons of stabilizer, I reached the target of 3 FC and have 70 CYA. Well now when I check targets in Pool Math it tells me I have a new target of 8 FC and my CYA is too high and needs to lower to 45.
Pool store test kit says all my current levels are in the OK/ideal range. I understand those are old thinking and plan to work toward Pool Math targets but I have a few questions.
1. Why would Pool Math tell me to target 3 FC but also at the same time tell me to add 6 gallons to raise CYA to a level that’s too high and would also then require a higher FC target?
2. Again, I’ll work toward what Pool Math says but since the pool is in OK/ideal range according to the test kit I assume it’s at least okay to get into at this point, is that correct?
3. Since my CYA is too high, should I focus on removing some water from the pool and adding fresh water to lower that first (which I assume will lower the target FC a bit)? Or should I focus on reaching the 8 on FC first?
Appreciate the help!
