- May 12, 2022
- 74
- Vinyl
- Hayward Aqua Rite (T-9)
Is it ok to use 60% algaecide? Was told to use it but I only trust what's said here!!
Thanks
Thanks
Thank you for ur answer but it's hard for me in canada to get my hand on a fas dpd test, making it hard to slam the pool. I'm oit of ideasHey Steve !!!!
You may use algecides if they are copper free. (Check the ingredients).
Just so you know (being new here), they do nothing to kill algae. They are a prevention thing only, and really only for closing. Algecide at opening (or during the season) burns up chlorine, leaving you with less of both so it's pretty counterproductive when you are treating the pool.
Follow the FC/CYA Levels, at all times, and algae will never be a concern.
If you have algae already, algecide does nothing to kill it and you need to SLAM Process
Hey there Chris, i spoke with a local pool company to come and fix the mustard algae but they said they were busy for next 2 weeks but told me to add some 60% algaecide to pool and would resolve.Steve,
Please tell us a little more about the situation. "I was told to use it" doesn't give us much to go on. Can you please describe the pool condition, problem you have currently, and your most recent test results. A photo would also be great. Whatever it is we will be able to provide help and it almost never is to add algaecide.
Thanks.
Chris
I get that. Algecide does zero to kill algae once you have it. For everything the pool store/service gets wrong, they misuse this the most.Thank you for ur answer but it's hard for me in canada to get my hand on a fas dpd test, making it hard to slam the pool.
Steve,Thank you for ur answer but it's hard for me in canada to get my hand on a fas dpd test, making it hard to slam the pool. I'm oit of ideas
I'm going to test water later today and post them and I will also take pictures and post.
Thank u guys again
Yep, that'll work for FC but reagent sizes are pretty small and you need at least the CYA test and PH also for a SLAM.Is this one ok??
Can you scrape some off and squeeze it between your fingers? If so does it turn green?What can u guys make of this
I have it as mustard algae, it dissipates when I move itCan you scrape some off and squeeze it between your fingers? If so does it turn green?
Then it's more likely mustard algae, reason I asked is it looked like some were black algae. I'd scrub and vacuum 'till you get your kit then post results here and start the SLAM. Your infestation looks pretty mild and should be easy to clear up. The treatment for mustard algae will clear up black algae also.I have it as mustard algae, it dissipates when I move it
