I know, I haven't even closed for the winter yet, and I'm already planning ahead! I'm going to redo my pad next spring. I plan to replace this single-speed clunker with a VSP and add a heat pump.
As you can see in the photo below, my pool was built with separate valves for the skimmer feed & the main drains. These work fine although they're somewhat difficult to turn. Is there any benefit to replacing these with a 3-way? From looking at everyone else's photos, it seems that a 3-way would be more standard to use here, but I'm not sure if there's a good reason for that.
Also for the main drain feeder, which goes high up into the air before coming back down: my pad is "downhill" of the pool. The pump is slightly below the level of the main drains. This configuration puts the cleanout well above the height of the drains (in fact it's up around the water level). This was obviously done deliberately by the builder, probably so you can open the cleanout without all 10,000 gallons rushing at you. I assume I should keep it that way? The big downside is that the unsupported vertical pipe is really wobbly, and I'm worried about stress on the pipe in high winds.
