Hi All,
Just curious as this is our first pool and we have been at a stand still for quite some time waiting on the marble to arrive from Turkey. Good News - it is here! The issue is our pool is rectangular and our home has about 5 different angles that are making the layout of the pavers an issue for me (maybe not for someone else!) Our vision is that the pavers will be laid in a diamond pattern with the apex of the tiles to be set at 45 degrees for the full circumference of the pool - so that leading off the pool everything is symmetrical. The trouble comes with the angles. The pool builder suggests we use the length of the pool closest to the house as the plumb line and let the pattern run from there... my mind does not follow that and my concern is that the other borders of the pool (left & right) will be wonky and out of place (ex: view from sunshelf). Pictures attached for reference. If anyone has 24x24 pavers on a diagonal in a similar situation what did y'all do?
Should we just let the length of the pool be the guide and let the pattern run? Will it make a difference once everything is laid out?
