Ok, so I am installing a 24x12 intex pool (had a round one at my last house). I have decided to have it semi in ground, 30" down. Here are some of my progress pics (ignore the mess, I am getting the patio done at the same time, also there is a deck being installed around the pool in a few weeks:
Oh, and before anyone thinks that the pile of dirt behind the pool is all you would have, that's after 2 full dump trucks have been taken away
Thanks to the information on this forum I was able to set out the pavers before hand!
Anyway, I am now moving the pump, filter, heater and solinator beside the house, at ground level, at the top right corner, so have to do some plumbing. I have no problem doing the plumbing but am really struggling with deciding which way to go and what I need. I have a skimmer & water fountain to install, so will have two pipes in each direction.
I think I am decided that I am going for this heat pump if anyone wants to comment? https://www.splashandrelax.co.uk/products/Pool+Accessories/Pool+Heating/Hydro+Pro+ABS+Swimming+Pool+Heat+Pump+Type+P20/32-+19.5kW/1636290405
Firstly, the whole sizes thing messed me up. So 40mm PVC pipe is the same as 1.5 inch, even though 1.5 inch is 38mm!
But ignoring that, I then wanted to go for some kind of flexible PVC that could glue to 40mm pipe. However, I can't source it where I live (Ireland) so it now looks like I have have to hard plumb it. So the question is 50mm or 40mm? The questoin is, is there any point in having 50mm plumbing when the Intex components are limited to 1.5 inch? I'll just have to use reducers at the pump, filter and solinator so might as well just use 40mm everywhere?
Any advice or comments are more than welcome. Thanks!
