We have an Intex Ultra XTR Frame 26’ x 52” AGP. We’re currently using the stock Intex 2500 GPH pump (model 28633EG). Its not easy to find specs on this pump, but I think it is rated at 1/4hp. This pump has an integral cartridge filter, we run with no filter in the pump and use an 18” Hayward sand filter. The pool has dual suction ports, one of which is hooked to an Intex over the wall skimmer. The system is otherwise stock (hoses, shutoffs, eyeball, etc.). We run the pump 12 hours/day.
The Intex pump has good flow when the inlet screens are clear and the filter is clean. Flow drops tends to drop pretty quickly when there is any restriction. Vacuuming is a miserable experience.
What I would like is a 2-speed pump that provides slightly better flow (say ~30%) than the Intex pump on low speed, with a high speed option for vacuuming or for when there are water quality issues.
So far I have tried 2 pump. One was a hand me down from a friend, from what I can tell it is an old Pentair Sta-Rite pump similar to this one: Sta-Rite Max-E Glas and Dura-Glas Full-Rated Pump Replacement Parts The motor is rated ¾ hp on high, 1/8 hp on low, with a SF of 1.65. Low speed was dissapointing, less flow than the Intex pump. I used the high speed to vacuum before going back to the Intex pump, and it worked great.
The second pump I purchased new: https://www.amazon.com/XtremepowerU...prefix=xtremepowerus+1.5+2+spee,aps,83&sr=8-5
It is rated at 1.5hp on high, and .46 on low, but the SF is only 1.0. I hooked it up last night; the flow on low speed was no where near what it is with the Intex pump (gauge on the filter was reading 6psi, vs. 9 with the Intex). On high speed the flow was not as good as with the Pentair pump, I didn’t get pressure readings but with the Pentair pump there was enough pressure that I couldn’t get the Intex hose to seal, but there were no leaks with the new pump. My suspicion is that the pump head/impeller is not big enough (undersized for the motor).
I’d like to keep this as budget as possible, but I also want it to work and not be a hassle and not be a cobbled together mess. I would prefer to stay with 110V for simplicity and cost, but if I have to go 220V I will.
What pumps will work for this? I realize that with a 2-speed pump the high speed will likely be overkill, but for a few hours a month on high I’m ok with that vs. the increased cost (and added complexity) of a VS pump. We live in Denver and the pool is open 4 months/year. (Sorry for the novel.)
Pete
Pete
