Re: Intex 18x4 Pool Chlorination
jenn8504,
I don't think anyone has officially welcomed you to the forum.
So... Hi jenn8504, welcome to TFP!
We're glad to have you here.
I thought I would point out that you have asked questions much along the same lines in another post you made around a month ago, here:
18-x-48-intex-ultra-frame-chlorination-t63644.html
It's best to keep all questions regarding the same sort of inquiry to the same thread. This way we can better help you, as we know what has already been asked and answered. It also keeps confusion down.
As linen suggested, read PS, then I suggest... read it some more. The link linen provided is a wonderful place to start, just explore from there the rest of PS as you deem fit and your curiosity leads you.
Keep in mind that pool shock, or "shocking" is not a product you buy at the store & just dump in your pool, walk away and expect it to be all sparkly and fine again. But instead, it is a process, one in which we refer to as
SLAM here @ TFP. That stands for "Shock Level And Maintain".
You can read about it here:
pool-school/shocking_your_pool
As well as here:
pool-school/defeating_algae
But really, you don't need to worry about that right now, nor, as far as we know with your pool at this point, even perform the process.
It looks like you have been using pucks for around 1 month, going off of your other thread. Depending on how many pucks you have used & what type, your CYA level may likely already be within our recommended range.
You need to get one of our recommended test kits, see my sig, then test your CYA along with a full battery of the other tests. Then report back here and let us know your findings.
At that point, you need to stop using those pucks ASAP!! All they're doing is making life more difficult believe it or not. They're adding more & more CYA with each new puck, as that CYA goes up, the chlorine levels have to go up as well. Unfortunately, the pucks aren't that smart. They put in a fixed level of each, pretty soon.... too much CYA & not enough CL. BAM! Pool problems!!
If you get CYA
TOO HIGH, you have to drain the pool and refill it with fresh water. You want to avoid this & the TFP method will help you do so.
1. By educating you as to how your pool water chemistry works.
*Which starts with Pool School "PS".
2. Armed with that information, how to then maintain it in the simplest, most economical trouble free way.
3. Keeping you out of the pool store & Walmart type places for your pool needs and instead in the grocery aisles where things are cheaper.
*The only thing you'd have to buy @ a pool store, or pool section at a big box store would be CYA.
If you have any questions at all and I'm sure you will.
Don't hesitate to post back, we love to help people here @ TFP because we love seeing people with sparkly pools and saving money as well as eliminating stress in the process.
We all do it, so we want to help everyone else get there too and it's not anywhere near as hard as it looks. It's 1st year of school level stuff. If you can read, follow directions and take corrective action... you can join our super secret private club. Shhhhh..... don't tell anyone.
:tongue:
