Has anyone seen the Pentair MagicBowl water bowl in person?
jza1736
0
536
Greenlawn, NY
I'm thinking about adding these to my build, but I'd like to see them in person. Anybody see them up close or own them? Thought or impressions?
Pentair - MagicBowlâ„¢ Water Effects
If you get them before I do. Can you Please post a little review?
I spoke to a Pentair rep. They sent me some additional pics and gave me some general info. They weigh about 60 pounds, are made of a composite material and have a smooth finish.
The grey conduit is a drain for the light engine area. There are 3 holes in the bowl two go below grade one for the water in the bowl and the other of the light. The 90 is just to ensure the light engine doesn't get flooded. When the PB drops the bowl and light engine off I'll take some more pictures.
One piece of advice the bowl sits on the white base. The flange needs to be the same height as the finished coping. Ours is sunken a little less than a 1/4 in and in some spots can see some of the leds from below. The bowls are flat on the coping but it's stone so there's a small gap.
I'm going to put a bead of window caulk on the edge of the coping, let it dry and place the bowl on it sort of like a gasket.
I was going through on line looking for info because we are redesigning our pool and planning on doing magic bowls. Have never seen in person, now as time as past it seems since your instal are you happy with them and would recommend? Any further advice?
Reactions: knee311
