1st off,
Thanks to all for the kind comments on my build, and support. I really am a fish out of water at the moment on this whole project as I have never built a pool before, but learning each and every day, and this site has been great for that.
My son Jesse 12, Whiskey, and I have been out cleaning up the pool area today in preparation for layout and excavation after my permitting is complete (fingers crossed for smooth permitting), and will post the pics later.
As to the few questions above:
- The stream is actually pool water, pulled from a return on its own VS pump to allow to adjust for speed and flow as desired. Kind of like a natural stream, sometimes a trickle, sometimes rushing. So we can vary based on mood. Also, I will be able to divert some water from the stream to kick up the flow from the spa into the pool if I want more flow than the pool pump is able to do.
- My thoughts on the lazy river are very similar as you mentioned. Once you use it a few times, the excitement may get old. Its not like a resort with a Huge lazy river, experienced on a vacation, and is new. Like you, I like the additional size of the pool, and for movie night, I can imagine about 10 to 12 of us and our close friends floating with drink in hand, watching whatever is the flavor of the week for movie night. Kinda like a drive in. The beam across the middle of the pool is approx 24 - 27', providing ample room to line up the flotilla of pool lounge chairs in a couple rows. Not sure if you saw the movie screen posts, they are about 12' apart, and the projector will shoot from inside the ramada as highlighted below.
- The benches and jets in the spa, I did not dig into too much, but will explore a little more. Thanks for the heads-up.
- The ramada walls that are pool side are engineered and will be shotcrete (highlighted below). The foundation only of the other walls will also be shotcrete, but with block on top of the base. We did submit extra permitting for this, so when we add the upper section of the ramada we do not have to go backwards for the posts support and approvals. There is also provision for sump pump in the ramada. Which the sink in the ramada will be plumbed into.
I think that's about it for now. Let me know if you come up with anything else. I appreciate the input, it will definitely help ensure I am not missing something.
Below is also some eye candy from the 3D renderings, which there has been several changes, but it is close enough to understand. The sizing is a little wonky in the rendering, that baja step is actually 16' wide x 9' 18" deep.
Jason
