One of the return lines is leaking. It's a new pool, but I'm sure it wasn't leaking until recently. So I'm not sure if I bumped into it while cleaning or a dog may have bumped into it. Either way it's leaking from the top portion of this fernco coupling. If you look close you can actually see it in the picture. I tried the obvious tightening of the band clamp and it seemed to make it worse so I backed back off on it.
Any suggestions? I kind of like the fernco fitting but not opposed to replacing it with a hard fitting if necessary. I just don't know how I'll do it. There's a valve back at the pump, but there's no stopping the water from coming out of the return fitting when I disconnect that fernco. Unless I somehow plug the return port inside the pool, which brings me to my next question... any idea on how to thread or connect things to the returns on a Doughboy? There's no threads inside, so I don't know how I would go about connecting a DIY aerator or novelty fountain, etc...
